Need help asap!!!
almst 92 tsi
69
Dec 5, 2008
Bremerton, Washington
What fitting do i need for a ss feed line from a 1g oil filter housing to the turbo?? A fitting size would be great. Tried the local company here and they are idiots and sold me the wrong parts. Thank you
Go to Mitsubishi and get there 2G oil filter housing restrictor or get one off a used 2G housing. You need this on a 1G because a turbo should only see a max of 55 psi of oil pressure. With out the rstrictor your turbo will see over 100 psi eventually destroying the seals. You can use a #3 or#4 braided s.s. line. I took my 2G restrictor and a measurement to a local air line and hydraulics co. to get my line made.
