mitsu composite vs felpro composite headgasket
byebyev8
344
Jun 17, 2004
kenosha, Wisconsin
I'm getting a new headgasket for my car and I'm woundering if there's any difference between the oem and felpro composite headgaskets. I've been told there the same.
A lot of people with no experience with the felpro will say it is crap. It is the same as a mitsu composite. It has steel sealing rings around the cylinders and is fairly strong for a composite. I have run 26 psi from a holset hx40 with a felpro composite and arp studs.
They are similar, but not identical.
They have a slightly different bore diameter and the firing ring on the Mitsu gasket is a bit wider.
However, they will perform equally. The difference in the firing ring will only affect the guys who run an o-ringed block or head and rely on a specific size and placement of the gasket's firing ring in correlation to where their o-ring is.
yea alright I blew a oem headgasket running 30+psi (no boost controler) without arp's.
make sure you check it for warp.
and make sure it is surfaced properly, NOT A BELT SANDER!
and take before/after measurements of the head at all 4 corners, from the VC rail to the head deck.
From what I have been seeing .008 makes the cumbustion chamber 1cc smaller
