1G Mishimoto radiator and fan shroud for 94 Eclipse
KianaLynn
34
4
Nov 2, 2016
Helena, Montana
i did the turbo conversion on my eclipse and I’m about to hook up the fan shrouds and I couldn’t find a post about anyone else doing it. I’m just wondering how to wire my old harness to the new one. Anything will help
Are the connectors not the same? If their not, then you should obviously get the proper connector and solder it to the correct wires.
Is this not the problem?
i got everything wired up. only problem is: the fans wont come on unless i turn the ac on. keep in mind i deleted my ac a loonnggg time ago. checked the fuses and one was blown so i replaced that. put that sensor back in that was on the stock one into the new one. still doesnt turn on by its self. been doing some logs to see how hot it gets generally and it sits between 203-206. and i know thats not good. any help would be appreciated. i did talk to the mishimoto guys and they helped me but still having the same issue
Factory 1g fans dont come on until ~203F, so your temps are not at all unusual. Have you let it warm past 206 to see if the fans come on after? It doesnt sound like youve allowed it to get hot enough to kick on. The sensor to turn them on is in the bottom of the radiator, is it installed and wired?
You have them both wired into the passenger side connector too? That's the main fan control based on temp. The driver side connector only comes on during A/C operation or if the overtemp sensor in the thermostat housing trips. Lots of people remove that sensor or unplug it, but that doesnt come on until 230F?+
    • Sdcryan1
