Archer Fabrications
- 9,719
- 707
- May 9, 2011
Scottsdale,
Arizona
hello everyone! i just moved to arizona and i finally have an e85 station a few minutes from my place. somethings i have gathered are that i need to go into my wide band settings and set the stock to 9,73 and then leave the rest correct? i leaned out my AFR table and upped my timing table, i was curious if i could get some advice if this is a good place to start. i normally run C16. I've done some reading but if i gather enough pertinent information ill do a good write up on the things needed in the tune to make the switch.
profile is up to date, but for those too lazy
6466 1.15AR Divided T4
9:1 CR
FIC 2150
Walbro 450
-8 Feed
-6 Return
Stock fuel rail (not anodized, i know this should be replaced)
Stock 2g tank
9:1 CR
FIC 2150
Walbro 450
-8 Feed
-6 Return
Stock 2g tank
take some timing out of that thing. Leave your fuel tables alone for now, and get your inj compensation dialed in. I'd get a sample of fuel and check it. You can do it with a graduated cylinder and some water.
