Making the switch to SD
TAL0NTSi
161
Dec 26, 2010
Westerville, Ohio
Alright, I'm another speed density noob, and I'm trying to wrap my head around it. I recently purchased the needed IAT and MAP sensor, as well as the plug and play harness from extreme psi. From what I understand the plug and play harness eliminates the need to splice into any ECU input. Is this correct?
If that is correct, and I'm using the harness, how can I still run the stock MAF to dial in SD? Especially since the harness uses the MAF connector.
I'm sorry if this question has been answered before, but I've been reading for hours with limited understanding.
My set up is updated in my profile.
If you want to use the MAS to dial in the SD table, you'd have to temporarily wire in the MAP sensor to another input (e.g. MDP) as this is the only sensor needed for the wizard. You'll still have to keep the MAS plugged into the stock plug.
How would I go about wiring the MAP sensor into the MDP input. That seems like the most simple solution.
Although, how difficult is it to dial in without having information from the MAF? Or is it even worth trying?
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
