ECMlink Log advice Please
Justyn
5+ Year Contributor
43
5
Sep 30, 2019
Toronto, ON, Canada
Good evening everyone. I've got a 92 talon and im having issues with my deadtime. I currently have my deadtime at 0 which doesnt seem right at all. I have a log to be view with any help and recommendations.
Here are details about my car
I ran a boost leak test, sprayed soap water found a few and fixed those.
Currently have PTE 580cc injectors (actual flow is 535cc)
Mechanical timing is set properly
Stock igniton system
GM MAF currently installed along with ECMlink GM MAF Wire.
Fuel tab set for the said injectors?
Yup I have them set for 535cc ( they are actually 580cc but actual flow is 535 )global is at -16 and dead time at 0 which doesn't seem right
I will see what I can do. I haven't ever had to do that.....a new challenge!!! Thank you Nick.
Just trying understand deadtime Alittle but more. I mean I tried my best to get my airflowperrev and fuel trims inline. To me it looks good. But to others it might not. This is my first log and I'm new to ecmlink. I've follow alot of the videos and check through the forums to get me where I am now.
Well you are doing the right thing. If you have the car running, adjust global fuel and watch the LTFT. If it shows 26, then it is adding 26% of fuel to what your setting is to keep the car running. In that case you would want to increase fuel so you would lower your negative global number. If it said -26, then it is pulling 26% of fuel from the mix to keep the car running so you would want to lean out the global to do that. To do that you will make the negative global number larger. You will want to adjust your global setting to get the LTFTs to within + - 5%. At that point I start looking at my STFT (short term fuel). If it is not within + - 5%, then I adjust deadtime to get it within that spec. Take note, sometimes you may need to put in NEGATIVE deadtime. It is all about what the car wants not necessarily hitting all of the numbers that we throw out.
I did exactly what you recommended. I think I got it lined up. Heres a log. Btw Thank you for helping me out with this.
I'm on my phone right now but I will look at your latest log as soon as I get to a computer.
No problem trying to help out. Everyone on here is very helpful. I build, tune and drive my cars so I can help out getting them going but I am no pro. Even I hire a tuner, LOL.
Marty
Just got a look myself and Kudo's, it looks good. Take it for a short drive and log it.
Thanks @jed344 !!!
Thanks guys I really appreciate it. Ill fine adjust the TPS and take it for a drive. If I have any concerns. Ill report back.
Log your drive so we can all see the motor under a load, just in case you have any issues.
:thumb:
Hey guys so I did a short drive and here are my results. Here is my first short cruise log. After the short drive I let the car Idle for about 5 min before shutting it off. I did a MAFcom adjust. now the car stays in open loop. Maybe I shouldnt have done a MAFcom adjust. I also did a TPS adjust. Here is the second log for that. Thanks guys
That's very strange. In my other logs the o2 sensor was working. Even after the short drive I did today. After I did mafcomp adjust and tps adjust its says in open loop. Would that be why it's stays in open loop?
