Advice on this log....please
selser420
83
Apr 8, 2005
Detroit, Michigan
Anything on here look abnormal or out of place? Mod list is current. warm humid day running about 11-12psi(spikes to 15 then falls to 11-12)
2nd gear
0.90V 42.4% 28° 2281 333.4Hz 0
0.37V 52.9% 25° 2156 327.1Hz 0
0.16V 57.3% 26° 2250 346.0Hz 0
0.18V 57.3% 25° 2313 371.1Hz 0
0.72V 57.3% 26° 2406 408.9Hz 0
0.84V 56.5% 25° 2531 440.3Hz 0
0.82V 56.5% 25° 2656 465.5Hz 0
0.88V 56.5% 24° 2750 503.2Hz 0
0.88V 56.1% 24° 2875 547.2Hz 0
0.88V 56.1% 24° 2969 572.4Hz 0
0.90V 55.7% 24° 3094 622.7Hz 0
0.92V 55.7% 24° 3188 673.0Hz 0
0.92V 55.7% 24° 3313 717.1Hz 0
0.92V 55.7% 24° 3438 792.5Hz 0
0.94V 55.3% 23° 3594 855.4Hz 0
0.94V 54.5% 22° 3750 962.4Hz 2
0.94V 50.6% 18° 3906 1044.1Hz 1
0.94V 47.1% 20° 4094 1119.6Hz 1
0.94V 59.6% 17° 4313 1339.8Hz 1
0.94V 78.4% 17° 4469 1534.8Hz 0
0.94V 89.8% 18° 4688 1604.0Hz 0
0.94V 91.4% 18° 4844 1604.0Hz 0
0.94V 91.8% 19° 5031 1604.0Hz 0
0.94V 92.2% 19° 5188 1604.0Hz 0
0.94V 92.2% 20° 5313 1604.0Hz 0
0.94V 92.2% 21° 5469 1604.0Hz 0
0.94V 92.2% 22° 5719 1604.0Hz 1
0.94V 92.2% 22° 5688 1604.0Hz 0
0.94V 92.2% 23° 5844 1604.0Hz 0
0.94V 92.2% 24° 6000 1604.0Hz 0
0.94V 92.2% 23° 6219 1604.0Hz 0
0.94V 91.4% 23° 6313 1604.0Hz 0
0.94V 80.0% 23° 6344 1604.0Hz 0
3rd gear
0.94V 100.0% 26° 4344 975.0Hz 1
0.92V 100.0% 22° 4406 1144.8Hz 1
0.94V 100.0% 18° 4531 1320.9Hz 0
0.94V 100.0% 18° 4563 1534.8Hz 0
0.94V 100.0% 18° 4594 1604.0Hz 0
0.94V 100.0% 18° 4688 1604.0Hz 0
0.94V 100.0% 19° 4781 1604.0Hz 0
0.94V 100.0% 18° 4813 1604.0Hz 1
0.94V 100.0% 18° 4969 1604.0Hz 1
0.94V 100.0% 18° 4969 1604.0Hz 0
0.94V 100.0% 19° 5031 1604.0Hz 0
0.94V 100.0% 19° 5094 1604.0Hz 0
0.94V 100.0% 20° 5156 1604.0Hz 0
0.94V 100.0% 20° 5250 1604.0Hz 0
0.94V 100.0% 21° 5344 1604.0Hz 0
0.94V 100.0% 21° 5438 1604.0Hz 0
0.94V 100.0% 22° 5500 1604.0Hz 0
0.94V 100.0% 21° 5469 1604.0Hz 1
0.92V 100.0% 21° 5531 1604.0Hz 1
0.92V 100.0% 22° 5719 1604.0Hz 1
0.92V 100.0% 21° 5719 1604.0Hz 0
0.92V 100.0% 23° 5781 1604.0Hz 0
0.92V 100.0% 23° 5719 1604.0Hz 0
0.92V 100.0% 24° 5875 1604.0Hz 0
0.92V 100.0% 24° 6031 1604.0Hz 0
0.92V 100.0% 24° 6063 1604.0Hz 0
0.92V 100.0% 24° 6125 1604.0Hz 1
0.92V 100.0% 22° 6219 1604.0Hz 1
0.92V 100.0% 21° 6188 1604.0Hz 1
0.92V 100.0% 21° 6313 1604.0Hz 1
0.92V 100.0% 21° 6281 1604.0Hz 0
0.92V 100.0% 21° 6344 1604.0Hz 0
0.92V 100.0% 20° 6438 1604.0Hz 0
0.92V 100.0% 21° 6469 1604.0Hz 0
0.92V 100.0% 20° 6594 1604.0Hz 0
0.92V 100.0% 20° 6563 1604.0Hz 0
0.92V 100.0% 20° 6750 1604.0Hz 0
That's pretty awesome timing advance! What's the last column for? Knock?
Where does it spike to 15? I think the tune's pretty good, just gotta tune out the little bit of knock here and there. What fuel mods do you have?
It shoots to 15 when you start boosting(boost creep style) then settles in at 12psi. The only fuel mods right now are upgraded lines and fittings from the filter to the rail. I have an EVO fuel pump and a rewire setup to put in the car still.....just have to make the time.
It looks good. You need to first at least rewire the fuel pump to be safe. Afterwards, try to do pulls from below 3k to above 7k.
