Idle log advice please
daplatano91
1,170
26
Apr 7, 2009
brooklyn, New York
Heres a log I just did any advice will be considered and appreciated. This is from my 1g GSX. Profile up to date.
I tried dropping the idle but it was rough. Kelford 280s at 850rpm isn't exactly the smoothest idle. Plus my solid mounts make it a bit worse. I only bumped the idle up through link so I need to readjust my biss then I will log the isc position and learned idle. But as of right now I know they are a bit high.
I have to re wire my coolant temperature sensor. The wire to ecu broke somewhere in the harness so I just locked the temperature through link. What is the tps volts supposed to be at 0 and 100%?
Thanks, will you be bringing the car out to Atco for Pan american?
