List Your Current Issues..
ESleazy
64
Dec 2, 2010
Colorado Spring, Colorado
You know stuff you've been meaning to work on, but things have come up/too lazy. You know.. I have a huge list...
Front windshield wiper fluid pump needs replacing
Rear wiper motor needs replacing
Find/Fix boost leaks
Fix exhaust leaks.
REPLACE BOV. Mad surge.. sounds like a horse is under the hood every time I let off.
I'm running rich as shit... need to fix that sooner or later!!
I have a lot more... I'm sure some one out there will be able to top this! I'm sure if I took one day to do this i'd be running new!
Replace the following:
front axles
change transmission gear oil
idle surge fix
change Japanese ECU
tune
install rear energy suspension bushing
change vacuum lines
Misc:
get tires for my rims
repaint whole car
I think that's about it
time and money for my reasons
weather striping/drip moldings need replaced
clutch needs upgraded(purchased just waiting for day off)
electrical issues
re-tune
replace coil overs
suspension issues
oil pressure guage
need I say more
I need to replace the head gasket, timing belt and a few other things. Need to fix the leaking power steering line. Need new tires. I'm sure other things will surface once I fix those.:rocks:
boost leaks
oil change
find coolant leak
exhaust manifold
lean at wot
passenger side wheel bearing
cv joint
passanger side tie rod
motor mounts
knock sensor
tcs
after all that finally put in holset
oh yeah messed up wiring
ball joint
finish exhaust
put dash back on
injector seals
clean engine bay and find oil/coolant leaks
rewire fuel pump better
hook up coolant lines to t.b.
get a auto meter boost gauge and throw faze one away!
finish gauges and a-pillar pod
windshield
paint
tires
lsd
struts
etc..
GSX
fix rust
put on missing ground effects(sitting in basement)
capacitor for sub
new tires
new rear lower ball joints
new Walbro fuel pump
Colt
new windshield
fix dents to roof thanks to ice storm 2 weeks ago(which took out my windshield)
lowering springs need put on
new sway bar end links
new fuel tank/Walbro pump
new timing belt/pulleys/bs belt/tensioner
dual-piston calipers put on(need rebuilt first)
new water pump
'90 oil filter housing and cooler
I need to...
Fix CEL issues after figuring out what is causing them.
Buy new tires and wheels.
Get new suspension because mine is shot.
Get a new paint job.
Clean it out.
The list goes on and on. Mostly just want to figure out why my CEL is always on.
GSX:
Getting my cluster to work correctly since none of my gauges work minus speedo and tach. Change plugs oil and fuel filter. Install FMIC w/ pipes and fix boost leaks. Get some new wheels and tires. Fix my always on time hot start problem and put in my Evo 8 ECU.:rolleyes:
