list of issues
broke gst
53
Oct 20, 2011
oceanside, California
6 bolt swap
20g
vrsf fmic
Hks ssqv
02dump
Full exhaust
Here is my issue i keep popping the motor fuse 20a and fuel just gets dumped into the car while about to start once started the RPMS go to about 3000 and very slowly go down to about 2500 rpm then it over heats. everything is new. To include head gasket!! I really need yhis car to run im running out if options..
Are you refering to a main engine fuse? If it is popping while you are trying to start the car, it maybe a short at the starter or in the starter.
As far as the fuel pump continuously dumping fuel that could be an ecu problem not shutting the fuel pump down after intially priming the system.
Trace wiring on the burnt fuse to see if there is a short
What injectors are you running and how are you tuning for them?
