List Your Current Issues..
ESleazy
64
Dec 2, 2010
Colorado Spring, Colorado
You know stuff you've been meaning to work on, but things have come up/too lazy. You know.. I have a huge list...
Front windshield wiper fluid pump needs replacing
Rear wiper motor needs replacing
Find/Fix boost leaks
Fix exhaust leaks.
REPLACE BOV. Mad surge.. sounds like a horse is under the hood every time I let off.
I'm running rich as shit... need to fix that sooner or later!!
I have a lot more... I'm sure some one out there will be able to top this! I'm sure if I took one day to do this i'd be running new!
Went out to eat with friends and when I went to leave it took me 5 cranks to start my car. Got it started drove home and when i went to pull the car in the garage I noticed some smoke and a burning smell, so I popped the hood shut the car off and my positive battery terminal was smoking and it was super hot :shrug:
Find out why my car won't stay on, until it reaches operating temperature, unless I'm on the gas, from a cold start
Random idle problem
Blown struts
Misaligned front bumper
Rusted through strut tower(s?)
Rust infestation on the underside of the car
Burning oil
Possibly blown turbo
Just about everything. All I need is for it to make it another year.
Do a timing belt job
Find an Intercooler and piping
Buy intake
fix the oil leak on the oil feed line(buy a new one)
find out why my Tach isnt working
do some better wire tucking
oh yeah and paint the car :D
then..let the modding/tuning begin!
'90 GSX:
- replace cut fuel hard line in engine bay
- replace Most if not all engine bay components (i.e. small electronics, master cylinder, reservoirs, etc.)
- Find transfer Case bolts thread patterns to have a local specialty bolt store make some
- Drop assembled Engine/Trans/Transfer case into bay
- Fix non-working power seat belts and ALL door electronics. WTF
''85 AE86:
- Buy ANOTHER full gasket set with a thicker head gasket :ohdamn:
- buy new twenty over piston rings (if needed)
- Rebuild 4AGE AGAIN :banghead:
- Drift :hellyeah:
'99 Stratus (my daily)
- Get a working Amp so I can get my sub working.
- fix exhaust leak and over pressured oil, then reset CEL
'92 Ranger (ol' lady's daily)
- fix the... oh wait, the one vehicle we own that I hate has no real problems and runs like a champ. :p
I'm leaking exhaust out of the manifold (although everything seems tight).
Leaking coolant from somewhere (a line above the turbo).
I need to get new tires (have them, just need to be mounted).
Need to install wheel wells.
Stop p/s pump from squealing (think I may have this one nailed down though).
Oh yea, I need to get this car legal!
oil leaks
boost leaks
allignment
brakes
exhaust leak
this damned high idle!!
body work
paintjob
headliner
sooo much more...
Need to install new TPS (when it gets here)
Somehow seal the leaky BBK throttle body (wishing the car didn't come with it)
Tidy up the wiring
Tune
Rebuild Turbo
Need alignment
Install/Clean the interior
Timing Belt
Peel off window tint
New radiator cap
Drive the car to find more problems to fix
As for me, I have the following issues
90 Eclipse
need to change transmission fluid
change both front axles
random idling issues (might because of the Japanese ecu)
broken driver side visor
install new turbo
95 Nissan Altima (DD)
tires
Front & Rear sway bar bushings & end links needs to be replace
fix A/C summer is coming and it dies when its too hot
axles too (I think)
Rear speakers don't work
All in all, all of my issues are pretty minor
