dwb
- 1,571
- 1,089
- Sep 9, 2021
Broomfield,
Colorado
What can cause brakes to go from firm pedal, then suddenly spongy for a pump, and then back to firm?
I recently upgraded my 1ga (non-ABS) single piston front calipers to 2-piston 3kgt base model front calipers (reman units). I also have new 1g SS brake lines on all four wheels along with a fresh brake booster vacuum line (cut to size EVO line with check valve).
I bled the front calipers like I've done many times before (single-man bleeding) - jug of old brake fluid with a tube submerged attached to the bleeder. A stick propped between the seat and brake pedal. Open/close bleeder, reposition stick, open/close bleeder, repeat half a dozen times. No more air bubbles. Refill brake fluid reservoir. Move to next wheel.
Everything looked good, no leaks, and never sucked air from the reservoir. Fresh fluid.
While bedding the new pads I noticed what I thought was just brake fade. Firm pedal after firm pedal and then suddenly the pedal is spongy and then goes back to firm the next pump.
So I decided to bleed all four wheels. Same bleeding process as above. No change, still random spongy brakes.
OK, so the master cylinder must be the culprit. I bought a new Dorman MC and installed it. Bench bled it first. This time when I bled the lines, I kept the bleeder open and pushed enough brake fluid through to bring the reservoir from over the max line to the min line. Then did 4 or 5 stick-bleeding like above. Refilled reservoir and made sure it never went much below the min line. I did this on all four wheels in this order: right rear, left rear, right front, left front. I pushed plenty of fresh fluid and there should not be any air in the lines. 100% fresh fluid.
It's still randomly spongy. For the most part the pedal is firm but when I do some spirited driving and brake right away, even sometimes when driving normal, I get a spongy pedal and then back to normal. Is it possible the proportioning valve or brake booster is causing this?
TLDR: installed reman front calipers and got intermittent spongy brakes. Installed new master cylinder. Bled the lines 3 separate times. Still intermittent spongy brakes.
