General Intermittent issues, sensor questions
kenamond
DSM Wiseman
3,225
68
Feb 15, 2006
Los Alamos, New Mexico
My son and I are trying to get my 1997 TSi-AWD back to "perfect running condition" and have hit an issue that has me a bit stumped. I'm pretty sure that this issue is what led me to park the car years ago and buy a new DD.
Cutting to the chase, the car runs perfectly or it doesn't. Schizo DSM. When it's misbehaving, it will start sputtering/missing at all conditions: idle, cruise and boosting. It's not a constant lack of power, it's bursts of working and not working, like it's cutting out for a handful of revs, then firing for a handful, etc. It might start up cold with or without the issue, start up warmed-up with or without and it can switch back and forth from good to bad while driving. It will usually be great or suck for minutes on end or for the whole drive. All day today it was misbehaving. Then we went to the grocery store tonight and it ran fine to and from. My current guess is a non-obvious sensor issue.
The only hint I have so far is that the aftermarket mechanical boost gauge would occasionally read hard zero in the middle of a drive for an extended period (many seconds) and then start reading manifold pressure again. It's not supposed to do that, but that didn't match the good/bad running behavior. We'd see this behavior with the boost gauge both when it was misbehaving and not. I've had that gauge, tied into the system the way it is, for 14 years and when it was my DD, it never did that. My boost gauge is mechanical and its vacuum line is tee'd into the line from FPR solenoid to the FPR, so this meant the solenoid was activating, exposing my boost gauge (and FPR) to atmosphere instead of IM pressure. Although it wasn't throwing an FPR solenoid code, we just replaced with a Mitsu (presumably OEM) solenoid today but the solenoid is still activating (middle of a drive for about 30 seconds but the car was running fine throughout the drive). We can bypass the solenoid, but like I said, the car's stumbling and the FPR solenoid don't happen at the same time, so it isn't just that. I realize that the car runs sub-optimally under load if the solenoid activates (running lean because fuel pressure would be too low without the IM pressure reference), but it doesn't correlate to the stumbling/main problem. There's gotta be something else.
My understanding of the FPR solenoid is that it helps with either warm or cold starts. I've read both versions and don't know which, but that makes me wonder, "what tells the ECU that the engine has just started?" Is it the cam or crank sensor? I recall that the cam or crank sensor signal tells the ECU to turn on the fuel pump, for example. I'm wondering if some other bad sensor is causing the ECU to trigger the FPR solenoid and that other sensor has something to do with the real issue.
So my main question is, what conditions cause the ECU to activate the FPR solenoid? What sensors, either directly or indirectly would lead to this?
Obviously, my other question is, what's wrong? Might not be related.
If you're still reading, some other background on what my son and I have done in the process of trying to figure this out:
We had started out with BLT and fixed a bunch of leaks. The car threw a knock sensor code and we saw that the knock sensor wire broke and it was oozing brown, so we changed that and TB gaskets, injector seals/o-rings while we were at it. No real change other than better BLT results (not perfect but pretty good - we have bigger fish to fry right now than getting it to hold 30psi forever). We did end up making a new high-end boost leak tester that has a built-in gauge, built in pressure regulator and a direct connector to the air compressor :)
The only other codes we read were boost control solenoid (forgot to plug it back in after doing some work) and the rear O2 sensor code (I have catless exhaust with no rear O2) which it never threw when this was my DD and which stopped throwing since we cleared it a week ago. There are no new codes after driving all week.
We've changed a few parts as well: coils and plug wires (plugs are relatively new NGK BPR7ES gapped to 0.028"), exhaust manifold gasket/studs/nuts and mani-turbo gasket (had an exhaust and stud oil leak), JB-welded a intercooler pinhole leak, better-fitting reducer-couplers at some intake plumbing joints and MAP sensor (the tab for the bolt on one side broke). My son temporarily fixed this by fabricating a metal strap that held the broken sensor body onto the IM - I was a proud papa.
We've been trying to log, but we've had some problems with the OBD2 reader working. It worked this afternoon and then didn't work this evening. If we can get that sorted out, maybe we can see something useful like weird STFTs when its stumbling or weird temps.
Thanks!
IIRC, The only time the Fuel Pressure Solenoid should be activating is during warm starts where if causes the fuel pressure to increase by the FPR seeing ATM instead of vacuum while cranking. Yours doing so while driving doesn't sound right.
Tee the boost gauge to the line before the solenoid not after. What kind of line are you using to connect it. The clear plastic tubing they ship seems to cause problems.
We've temporarily bypassed the FPR solenoid. I installed it that way, because I read some thread that said to do it that way eons ago when I first started wrenching on this car. Yes, it's the thin white plastic line. Also, if it were tee'd in between the IM and solenoid, it wouldn't have given us this clue :)
Anyway, my issue is why is it triggering the solenoid while the car is running and has been running for a long time? What is the ECU thinking it's doing? Hoping that might shed light on what's really going wrong.
We've been hit and miss with the OBD2 reader working, but we're gonna try to see what's different when it's running well vs stumbling. Flyin' blind, though.
Thin white line???
Sorry, the boost gauge line is a thin white plastic tube running from (a) a tee connector on the vacuum line between the FPR solenoid and FPR and (b) the mechanical boost gauge. The material is like plastic rather than rubber. There's a rubber adaptor on the tee fitting. White tube press fits into the rubber adaptor. White tube runs through the firewall at the steering column, under the carpet, up under the A pillar cover to the gauge which is mounted on the A pillar. Anyway, that's not the issue, all that stuff isn't leaking. But because it was on the "downwind" side of the FPR solenoid let us notice the weird FPR solenoid behavior.
MottoMattX's recommendation gave me a clue that we'll track: if it's idling with this issue, we'll jumper my 4Runner and see if anything changes...or we'll measure voltage, not sure yet. The battery is brand new but the alternator is (unless I forgot that I changed it - possible) original. I know the ECU gets flaky if voltage is too low, so maybe it's low-voltage schizophrenia?
BTW, my daughter and x-wife are in your (Steve) neck of the woods nowadays, somewhere between Denver and Boulder. My son (17) seems to be catching the DSM bug (he's the motivation behind this revival), and it might be fun/interesting/disaster to meet in person some time if we're in the neighborhood. "Steve" taught me a lot!!! We can do dinner, but I'm buying! The drive alone would be a hoot for me (all backroads like I'd do back in the day for snowboarding or concerts). I drove to Denver once just to get a new front bumper cover.
Gotta figure out the issue, though.
