twicks69
Supporting Vendor
- 4,314
- 2,035
- Mar 12, 2004
Milwaukee,
Wisconsin
I agree that's why I don't think either the 4088r or the non BB version.
I agree going with a build head is usefull always but not needed for your goals. You said you want to know what's best to buy with the money you have to reach your goals I think upgrading your INtake manifold and cams would be money better spent. Not to say the mangus is a bad manifold just for 650whp I think the welds begin to become a liability. You could sell it for $3-$500 and use the money to upgrade to something fitted up with a q45 tb or such and breath a little better up top.
The throttle body isn't the restriction -- it is the manifold itself. As well, his cams are just fine.
You can do over 700AWHP on a magnus; but it is much less efficient on the 2.3L and 2.4L engines at higher rpms and higher boost levels.
I'm sure items you suggested would probably be a slight improvement, however... I'm working on an extreme budget here and everything I have read suggests that a 62mm throttle body, FP3 cams, and a magnus intake should get me to my goals. I think the best bang for the buck upgrade I can make at this point is a turbo upgrade, but the real debate I've been having is whether to spend $200-$300 upgrading my scm6176 to a full T4, or spend $1300 and get a brand spanking new s372.
won't see numbers like that with those same parts. I know guys with bigger turbos than him and better parts that make less than 600whp simply because they didn't have someone to tune it professionally.
