XC92
5+ Year Contributor
- 1,654
- 376
- Jul 22, 2020
Queens,
New York
I've been having idle surge issues and have begun the process of diagnosing and fixing it. The idle position switch seemed iffy with the cable about to snap off so I fixed that, but it didn't fix the surge issue. Next steps are to remove and clean the throttle body and idle control servo and replace all the gaskets and o-rings, check for vacuum leaks, test all the applicable sensors and check the connectors and wires, and so on. You know the drill.
But I thought I'd first check the BISS, and it seemed to be turned pretty far out. It took 5 or 6 complete turns to go all the way in. Is that normal? I turned it all the way in, then back it off half a turn or so, and the surge appeared to go away, although granted I haven't driven the car and let it get up to temp. But idle is now around 800rpm, where before even without surging it was well over 1000rpm, and when it surged it cycled between 1200-1400rpm once it got up to operating temp.
Have I potentially fixed the issue, or just masked it? I had suspected that it was actually a bad or stuck ICS, and still intend to clean and check it both electrically and mechanically, but could this have actually been the problem?
