1G Help on first 6 bolt built
Badger167
Apr 29, 2019
Fort Wayne, Indiana
Looking at complete gasket sets
and kind off stressed out
any recommendations would be helpful Thanks so much!
I build them and I buy my gaskets separate since some of the rebuild components (oil pump, water pump, etc come with there own). Some of the gaskets that aren't thought about a lot are the oil drain BOLT washers (with a gasket). So lets run down what you need:
Front case gasket - comes with oil pump
OFH gasket - comes with oil pump
Water pump gasket - comes with water pump
Water tube O-ring - comes with pump usually
Front main seal - comes with oil pump and already installed
Rear main seal
Thermostat housing gasket
Head Gasket
Intake Gasket
Exhaust Gasket
Valve Cover set, with sparkplug well seals
Throttle body gaskets
Timing belt
New Timing pulleys
OEM Timing Tensioner
Balance shaft belt if not BSE
Balance shaft belt tensioner pulley
Harmonic Balancer - I always replace, even if with a unit from RockAuto
Thermostat
Rings
Main Bearings
Rod Bearings
Oil Pump - OEM or ACL
Turbo drain gaskets
Freeze Plugs
Oil Pickup Tube gasket
Rear Main housing gasket
Oil drain bolt gasket/washers (2)
Just about forgot these - 8 aluminum crush washers for the oil squirters, if removed
Get the head and block decked or checked for true flatness and correct if needed.
Clean the hell out of the crank, like this......
https://www.dsmtuners.com/threads/pull-your-balls-to-properly-clean-your-crank.472402/
See post #6 on.
I do all of this and more, but this is the basic part of my rebuilds.
I think that is it, if I forgot something, lets get it added. :thumb:
Marty
Awesome guys! Thanks so much for the responses!
Supper stoked for this project
I am building a 7 bolt right now for my son and am just about in the same area as you. Here is what I started on.........I smooth out the oil supply passages on the front of the block on all of my builds.
Just attention to small details........
I will be smoothing out the oil passages for sure, I really appreciate the help
Even if I'm a "Probationary Member" I'm on this site daily
and enjoy looking at all the forums
Thanks again
And I enjoy helping out so it's not a problem ask away. :thumb:
1 tip on smoothing the oil passages is to leave the old oil pump gasket stuck to the front of the block just in case you get out of the oil galley. It'll save you a headache.
Then clean that surface when you are done!
You can use any gasket set even from ebay but I recommend to use Mitsubishi gaskets at least for oil pump, oil filter housing and oil pickup and a name brand head gasket. And don't reuse the old stock head bolts. You won't regret.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
