Built 6 bolt crankwalk? Please Help.
91DSMdave
223
5
Jun 23, 2009
Strattanville, Pennsylvania
I am so angry right now, and can't find any explanation.
I have a 1992 Talon TSI, with a fresh motor, 2800 miles. Weisco Pistons and Eagle Rods, all new ACL Tri-Metal race bearings, and an ACT 2600 or 2900 Clutch (Not sure). I did a timing belt on it yesterday because my friend dropped a bolt down my cover, and just decided to grab ahold of my crank and pull back and forth. There is probably 1/2" in and out, not sure if that is accurate but its definitely not normal. Crankwalk. Now when i put the motor in, it did the whole RPM drop when i pressed the clutch, but why? I'm so confused as to why my car is doing this to me. I'm so heart broken right now, i'm a college student and i put every extra dime i had into my car to get it running. Please help i'm so confused.
Did you build the motor? It could just be the crank-pulley, so don't freak out yet. Although something could have went wrong with the assembly of the bottom-end, so it is possible to be 'walking'. And if the RPMs are dropping when you push the clutch, that's an indication of thrust-bearing failure.
And as far as the highlighted, the more you think all weird like that, the worse everything will be. That's just an odd way of thought, dude. It's a car; made of metal. Not a person who is trying to f you over.
Yeah. It had to be my clutch setup to make it go out. Cause it did that with my clutch not the one that was in it before. I did the belt because from it moving the belt got all ripped up on the edge. I'm going to tear it apart, but I'm going to probly need a clutch kit, and main bearings, rod while I'm at it.
Invest your money a little better. A cheap civic that is reliable and won't cost an arm and a leg is probably the smart thing to do during college.
Just my 2 cents. Good luck and I hope its just the crank pulley.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
