2G Help me with fuel pump replacement
samian rahman
May 25, 2019
ozone park, New York
So I bought a fuel pump. Electric fuel pump from Carter . I'm seeing 2g videos on fuel pump change and my fuel pump dosent look like that. Theres nothing ti tap with hammer. U just pull jt out and there seems to be only 1 feed line. Will update pic and will this electric one work instead. The new box also didnt have a gasket which sucks.
a story I'm so stressed. My car just got on fire. Wanted to check if my car was getting oil. Took the rail off and had someone crank the engine. No oil was coming. So I tried some other stuff and suddenly some oils gushed out and feel by the injector. Now I put the injector and didnt realise that the seal was missing for one and oil went in and bomb mini explosion sound and cars on fire. Almost lost an eye but It burned for 30 sec toll i got the extinguishers. No lines burned out. Can see it was almost falling of. Tried starting car later again and everything seemed fine. Was cranking and all. I know I was being a retardI was just rushing if.
