Help! 2g Talon wont start
chronicvex
189
May 29, 2008
Crofton, Maryland
Ok the car has been sitting for a couple months... battery was drained so I have jumper cables on it and I tried to start it, cranks slowly.. i hear clicking from the inside... throttle pedal is not coming all the way up. help please...
If its cranking slowly your still not getting enough juice to the starter, the battery needs to read 12v at the terminals before you try starting the car. Even then, if you go to start it and the battery voltage drops below 10v while its cranking the battery needs replaced.
The gas pedal issue is separate from the no start, you just need to adjust the tension on it at the cruise control box located on the firewall just above the battery.
:dsm:
