head gasket question?
thesmartestyet
74
Aug 11, 2007
coghlan, New York
im getting ready to replace my head gasket with some arp studs on my 95 talon i was wonder if theres any problems im going to run in to? so if you have done your head gasket let me know so i know what to expect thanks
Make sure you do the timing right, other than that, its fairly basic.
ive never done this but make sure you drain your coolant first or you'll be doing a whole motor build. take you time. clean the surfaces really good. (if you can afford have it decked) its like $50
(ive seen alot of this happen and its not good your motor will not like the coolant.)
i have just done my 1g laser with arp head studs, and my roommates tsi 2g will have arp head studs used in it. make sure u have the head checked at a machine shop for flatness, have milled only enough to bring it back to specs. second, it would be good to check the block as well to make sure it is perfectly flat also. Lastly, ARP head studs are made from a much harder material than stock bolts so it is imparitive that they be torqued to the specs sent with the studs!!! NOT factory specs. 1g specs are final 120 LB/FT. and 2G should be around 65 LB/FT. Hope this helps. I have pics of my rebuild, so i can upload them if requested.:dsm:
Hope this helps : http://www.dsmtuners.com/forums/cyl...707-project-rely-ability-6-bolt-rebuild.html; at least it will familiarize you to the process of what you need to do to get the head back on. Remember, do a bit more research; torque from the middle out and torque in steps. 30 ft/lb (do the ENTIRE sequence for all studs), then 60 ft/lb, then 85 ft/lb with ARP supplied moly lube. If you are using conventional oil, torque to 110 ft/lb.
Heres how your suppose to torque them...
Wow Tom look at you getting your thread out to everyone :D HAHA
Tom did a great walk through on his build, and if you check his thread out you shouldn't have a problem with doing this.
To the OP: Nice s/n is suit's you ;)
alright thanks for all the help i am pulling the head off the car tomarow i will let you know how everything works out
HAHA, i'm a forum whore, mind as well be a thread whore too :D Besides, what good is doing all that work taking pictures if no one is going to see it? :p While I have your attention, Happy new years to you too!
Doesn't the cometic require a certain smoothness (RA) on the head and block surfaces? I was under the impression that if it's not at a specified RA it will be worse than a stock HG. Also, is it even worth using the cometic one for a stock 7 bolt, let alone a 7 bolt using a 16g? I know you already have it, but below a certain power level aren't they more trouble than they are worth?
Yes, yes, and yes. Cometics, Titan ICS copper, mitsu MLS all require near perfect to perfect mating surfaces; not your typical "mill til it's flat" type of job. On cars that are running <30 psi of boost (or so) and/or are not extensively modified, there is no reason NOT to use an OEM headgasket. Hell, Most guys running that much boost and are making 500+whp (Keith from turbotrix ran 10's on a stock headgasket) still use OEM composite's, I know I am.
i just replace my head gasket and its time for me to put the timing belt back on i have all my marks lined up but when i go to turn the tensioner to get some slack (counter clock wise) the tensioner will not move at all. help?
Is the bolt loose on the tensioner? I know it's a dumb question but i have to ask. Also i believe that on a 6 bolt the tensioner pully rotates up and on a 2g 7 bolt it rotates down. But i could be wrong, i just remember reading that on here some where. I always rotate mine upwards, tighten it and then pull the grenade pin. I've been on a 6 bolt for so long i'm trying to forget everything i can about 7 bolts LOL
Also, it helps to pull the auto tensioner completely off untill you're ready to put it on and pull the pin on it. I get my belt on completely, set teh pully loose, then put the auto tensioner on and set it and go.
I hope that's what you're talking about.
GO to vfaq.com and read the timing belt install , great info there !!!
Correct. 1G pulleys tension in a clockwise fashion and the 2G is a CCW rotation. As far as the grenade pin, that should be the LAST thing you do before you button up the car. That includes after the last step of rotating the engine 6 times manually.
well after a little of research i need to compress the hydrolic tensioner and pin it so i can put the belt on
Correct. Remember to tension the C-clamp 1/2 revolution at a time and waiting a min. between rotations.
im using the belt that was on there but it only has about 5000 miles on it if that and i think im going to try to use the tensioner thats on there now
