Mikey_Dsm
- 69
- 27
- Nov 1, 2021
Layton, Utah,
Utah
Anybody have any experience using this particular head gasket?
shop.boostinperformance.com
My cometic mls started to mix oil and coolant recently after having the head and block machined for a fresh rebuild and I’m looking into some different head gaskets.
Currently have standard size super tech valves on the head and for the block wiseco pistons with 8.2:1 compression ratio, bored .020 over with eagle rods and arp head studs and mains. The stock intercooler with a 14b.
Do plan to upgrade everything in the future for 400ish hp. My profile is accurate to what I’m running to.
Don’t know wether to use an oem MLS instead or go with the SCE vulcan because it’s a composite / MLS hybrid that use rings to make sure it seals properly.
Or if I should go with a felpro composite?
I did do some research and I saw good and bad things for all of them
What’s the best option for my power goals?
SCE Vulcan Cut-Ring Head Gasket (DSM / Evo)
SCE Vulcan Cut-Ring Head Gasket (DSM / Evo), SCE Gaskets, Cut-Ring, Head Gasket, MLS, Hybrid, Mitsubishi, DSM, Evolution, Evo, Evo 4, Evo 8, Evo 9, Eclipse, Talon, 1G, 2G, 4G63
