HE351VE Manifold Development
I thought we were going 1-1/4"?
"In the beginning, God created Fluid Mechanics by Bruce Munson": Amazon.com: Fundamentals of Fluid Mechanics (9780471442509): Bruce R. Munson, Donald F. Young, Theodore H. Okiishi: Books
I can't speak from experience because I'm not a manifold fabricator.
Dr. Munson would say:
At the same flow rate 1-1/4" will have a laminar flow velocity roughly 1.4 times higher than 1-1/2", but the head losses will be greater especially in minor loss areas like bends. Look at the moody diagrams. The runners should be the smallest diameter that keeps your flow laminar. Also, the runners should be long enough for flow to fully develop, otherwise the exducer efficiency will go down since undeveloped flow is "stickier" than developed flow.
By the way Kevin, you are correct about long runners they help the flow profile develop nicely in the pipe.
Hey, can Brian weld on an extra bung at the collector in case we want to do exhaust backpressure measurements? I have a feeling that will be useful for our testing.
We can have one cut from stainless. I have no issue with that.
Here is what has to be done to make a T4 flange work. I started the collector, this is where it is at.
Not exactly about manifold but related...
Has anyone thought of lightening exhaust housing? Even couple of pounds would be good. Actually cold side can be lightened too I think
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
