knochgoon24
DSM Wiseman
- 6,135
- 98
- Jan 29, 2008
Troy,
Michigan
You should be able to eventually get a good SD tune dialed in, even with VGT, if the controller is good and controls the vanes in a repeatable way. I wouldn't want to be rough tuning the vane control while on an SD setup.
I'll go through a list of updates. We are thoroughly testing the controller's inputs, hardware, and writing software.
). We will do more logs with the pressure sensor/maf signals streaming to confirm.
)... What's the difference between a Subaru and a cactus? A cactus has pricks on the outside.
I'll get some new data plots up soon. Next set of plots I will see if I can get the MAF signal as well. In theory, we'll be able to plot compressor efficiency with that infomation.
Your thermistors aren't a technically bad idea, send me a PM if you want to have a more detailed discussion about those. Also let me know if you need TC sensors.
