Galant 4g63 SOHC 16 valve ECU
JC88
Mar 18, 2017
San Jose Pinula, Michigan
Hey Everyone. So I have a huge problem. I have gone to 6 or 7 mechanics here in Guatemala and they all have told me that my ECU is gone. So I say ok, lets buy a new one. The only place where I have seen a ECU its a the dealership and they want $1000.
For this price I can buy an APEXI mod ECU. I need your help in knowing if I can replace this ECU with a more common one or where I can buy a used one.
My ECU is MD339838. My Galant has been in different shops for the past 3 months and the last thing I wanna do is sell it for scrap metal. Can someone help?
Thanks!
Maybe I can help from the UK, we have Galants and I'm sure someone around on eBay will have an ECU that's usable for you,
How do you know exactly your ECU has gone?
What is the problem with the car?
The car starts and 5 seconds later the check engine light comes on and the car shuts off. I have changed the crank shaft sensor and many other things. It will start again, and again 5 seconds later it shuts off.
Maybe I can help from the UK, we have Galants and I'm sure someone around on eBay will have an ECU that's useable for you,
They have followed every single electrical line and say the the computer does not provide the correct readings. The ECU is MD339838. If you do find one I would appreciate it so I can get it.
If it's starts and runs from 5 seconds it sounds like a sensor more then the ECU to me, have you checked water temp sensors for the ECU, have you checked all the fuel system, coils or plugs and charging system as this can cause it to shut off aswell, as a precaution check all vacuum lines Incase of a leak that's causing it to stall all the time,
Have you tried salvage yards? We sell ECUs at my work all the time, generally about 50-75 bucks with a 30 day replacement warranty. There's gotta be someone near you.
Have you got the other codes on the ECU, or take a picture for me, they come with different codes but are on 2.0 16v engines still so I may need to use the other codes here for a match
I will be checking the temp sensor for the ECU.
Now, for the rest, fuel systems, coils, plugs and charging system has been checked.
Let me take a picture and I will post it, I will be posting a video tomorrow so you guys can see what is going on.
What code is the check engine light coming on for?
I've tried verifying with a scanner but no scanner is allowing me to verify that.
I have tried all type of salvage yards, the only have for the 2.4 or 2.5 v6. They others for Eclipse, Lancer etc but I don't know if they will work for my car.
There is no 16 valve 4g63 in SOHC form. The SOHC 4g63's are all 8 valves. If you got a SOHC 4g63 then I believe your Galant is 93 or older meaning its OBD I which most modern scanners won't work on let alone plug into. You'll need an analog multimeter or a LED test light to check the codes for the CEL. Also I'm almost positive SOHC 4g63's don't have a crank sensor. You sure you have a 4g63 and a not a 4g64?
Hard to believe I know, but I'm looking right at it, it is a 4g63 BA single cam 2.0. The year of the car is 2000
Jc88 what year is your Galant?
According to my sources the ECU you need comes from a 8th gen Galant, and they only had a 2.4L 4 cylinder engine, or a v6, so you likely can use a 2.4 ECU.
they are very common at my local parts yards.
Maybe in the US, but Europe got a 2.0 as well in a 4g63 and 4g94
Sorry I thought the ops location was in the USA, now it makes perfect sense, world markets have all sorts of variations on motor options, but I suppose a European member would be able help you out, because again all we ever got in the USA I mentioned, you might have better luck on the Galant forums.
He is in the US LOL, he may have an import or infact a true US car with a 2.0, only he can confirm though
Really :hmm:, maybe somewhere in Guatemala, I've honestly never heard of a San Jose Pinula, Michigan. Where is it located?
Oh well assuming it's in the states, it could also be a swapped import motor, to verify you can write down the VIN number stamped on the block, if it matches the frame VIN then you will know the engine is original, also try running the cars VIN on a decoder online and see if it lists a 2.0 or 2.4 motor.
Oh well assuming it's in the states, it could also be a swapped import motor, to verify you can write down the VIN number stamped on the block, if it matches the frame VIN then you will know the engine is original, also try running the cars VIN on a decoder online and see if it lists a 2.0 or 2.4 motor.[/QUOTE]
I just went by the state LOL I'm not sure on names or towns in the state.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
