1G Four codes! Barometric, coolant, air temp...
lilbacha
6
Nov 6, 2004
Bartlett, Illinois
I have a 90 AWD, and here's the issue. If I don't start my car for a day it takes at least 10 times to crank the car and another 5 times to stay on.
When it stays on I get the following four codes:
12 air flow sensor
13 air temperature sensor
21 coolant temp sensor
25 barometric pressure sensor
I thought my MAS was bad, I replaced it and the results weren't any better. I took out my ECU and opened it up, everything checks out okay there as well. My Radiator fan wasn't working recently so I replaced it along with a radiator fan switch and that worked for a day. Now the fan only kicks on when I turn it on manually by pushing the AC button and flipping the switch. Otherwise it begins to overheat.
I have No idea whats going on and any comments will really help...
Also, my coolant temp is reading 95-100 when the needle is dead center
I haven't done any wiring recently. I just took out the ECU and examined it back to front.
Thanks for the quick response!
I had also hooked up an EPROM ECU to it and it gave my the same problems of hard starting
i just bought a coolant temp sensor hoping to fix one of the problems, we'll see what happens
I traced the wiring harness for the MAS to the ECU and it seems to be just fine.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
