420A Coolant temp help
2000mitsygt
56
May 5, 2012
barnegat, New Jersey
Just bought a bottle of lucas coolant lubricant says it runs up to 20 degrees cooler lets see if it helps. Is there any other way to keep my car cooler do they have upgraded fans any ideas the colder it runs the better
You can buy a 170 degree thermostat from dsmparts.com and it would run cooler that way and also an all aluminum radiator will make it run cooler but they are around $250
You can get a slightly higher rad cap to help cool it, does not do alot but it slightly helps, other then that a ln aluminum rad will do more,
