Replaced HG. Coolant temp gauge, Coolant temp sensor NOT WORKING.
DallasN2O
84
Aug 14, 2005
Texarkana, Texas
Coolant temp sensor is reading -74f according to logger.
Gauge on the dash is not working either.
Both are hooked up.
Any tips? I've done my best to check for breaks / shorts in the wire, don't see any.
Do these have a common ground that they need in order to function?
Both were working fine before i replaced the HG.
Note that dash gauge uses the 1 wire ECT sensor while ECU uses the 2 wire ECT sensor. Try grounding the 1 wire sensor's wire (yellow-green), turn key on, gauge should go to highest. This should tell you if the gauge is working. The sensor itself should read 104 ohms (+/- 13.5) at 158F. It increases resistance with lower temps.
