FMIC short route vs long route...Personal preference or actual difference??
AlaskanDsm
1,124
17
Oct 21, 2007
North Pole, Alaska
This topic has been beaten to DEATH!!:beatentodeath: I have spent the last 2-3 hours reading as many of the post as i could find. In the future I hope to be doing some upgrading on my car and I just want to look into the options I have for running the piping on my car. From what I have read...
Long route:
-Cheaper (doesn't require the slim fans and some other minor modifications)
-Retains stock fans (Some of the Larger FMIC don't aways allow for enough cooling on the already smaller stock radiators
-Is longer (*suggested* lag time in spool)
-Still gets you into the 11's and 12's
-Seems to be more common for larger FMIC
-Someone already has a hard UICP (doesn't want to pay for the extra to replace)
-More bends (making pressure have a longer "walk" to the TB)
-Possibly makes BOV louder (more air to circulate?)
-More of a "BOLT-ON" feeling
-Has more chances of boost leaks (longer w/ more couplers and piping)
Short Route
-More expensive and requires some minor modifications
-*bragging rights* (as someone had mentioned for an indifference between)
-Shorter route ( *suggested* faster spool time)
-Seems to be less common Larger FMIC
-Clears the wheel well area (SMIC area can be utilized EX. auto tranny cooler)
-The turbo is as close the the TB as possible (For a more responsive spool and engine)
-Has a cleaner look for you car and engine bay
-BOV seems to make a lot less noise (less air to circulate?)
-A/T transmission coolers need to be moved sometimes because the hot pipe is in the way
-Harder to install on a 1G (not sure about a 2G)
-uses smaller fans on radiators that might already have some issues getting air through the FMIC
-Has much sharper transitions(worse for airflow)
I can't seem to point too many other things out. The only other major thing that popped out was that long route and short route really aren't too much of a difference. DSMlink and AFC, Now you are talking about a big difference.
A lot of people that talked in the threads talked about how you might want the short route in the long run. Or how you bought the 2.5 exhaust and wished you had bought the 3. Another would be about removing the cat and running a straight pipe there. Both aren't necessary but something can slightly increase performance.
Ludachris:
I believe that less piping will always be better than more piping. The shortest distance to the throttle body will always win out. Now, the only way to test this of course is to try both on the same car with the same setup. I doubt that many people have done this. Trying to test two different cars won't tell you anything. There's too many other factors involved, and we all know the golden rule - all cars are different.
So my question stands? Is the the difference routes more personal preference or does it really have enough gains to spend the extra few dollars besides looks and space saving...to get the short route? I'm not asking which is better in your opinion. I already read a lot of that haha. Just if its a personal thing or if there are actual gains equivalent to the extra money spent.
Wow..sorry it was so long.:boring:
...?Why bring up such a old thread? coincidence? LOL I recently cut a good 3 foot off my original pipeing on the FMIC. Heres my input on the difference. I went long route at first for cost, and the differences I experienced are pressure drop for one with the SMIC I was boosting steady 16psi. After the install that number went to 10-11psi. zero boost leaks on this one. I had to turn the boost up quite a bit to make up the difference. Which led me to think that my turbo was being over worked so to speak.
Also with the long route pipe set up I noticed the hot side of the piping was much hotter after driving. When I changed to short routing the hot side the hot side pipe temps went waay down, also because I could turn the boost back a bit for the same psi I wasn't maxxing the turbo as much.
After I swapped for a shorter route, on the hot side the intercooler wasn't nearly as warm to the touch it was significantly cooler then before. I must say the difference in a SMIC, and a FMIC is pretty huge as far as seeing knock. It is non existent, and just to think I almost went back to a SMIC...LOL
