fmic install help
zachyd23
127
Nov 11, 2011
Bark River, Michigan
Alright guys I have a 92 talon tsi and I have had a jdm fmic lying around.. how do I connect the fmic piping to the stock throttle body and j pipe? Thanks
What do you mean by JDM, Is it a kit for the eagle talon?
Its probably a universal for a honda, Depends on how you would set it up, i had to cut into my sub frame to get mine to fit but i took it of because i didnt like the way it sit on there an the brackets werent strong enough for the 4g63. so i cracked it haha. but yea, post pics an we can help you
Got it from miller import parts and he said it was on a 1g talon so it better work LOL and i'll post pics up in a few minutes.. I have the stock throttle body pipe that came on the car and the j pipe for the 14b which are both a lot smaller then the piping..
Alright so how do I attach my much larger piping to these stock pieces?
Hmm how much is that? Trying to spend a lot of $ right now and i'll have to take some toomaro.
I need a 2g elbow or can mine work?
Well right now its about getting the car running and not about power loss haha it is my winter car and I need to get it ready.
well you will still need to upgrade it because the 1g elbow port is to small. unless you use the stock hosing an use metal piping from fmic to the bov pipe an lead it to the j pipe. im gonna get a srt4 fmic because the ports face inside an its a shorter route for the air to flow. but how were you planning on running it?
well it wont work because the ports are to small 2g is a upgrade unless you order the whole kit with the elbow an all. because your losing power with the 1g elbow
There are many different reducer couplers and weld on reducers so it most certainly will work with a little fabrication.
I'll post up some pics a lil later after I get home from work and see what you guys think.
Its really difficult to tell you if it will work without seeing the pieces of piping you have for your intercooler kit. if you take pictures of the piping you have that would help. and if all else fails...we are running a SUPER deep discount on our kits. :p
What kind of discount are we talking about :D
you can find a elbow for like 25-30 bucks bro, i was looking an found some guys parting some 2gs. so get at them an see if you can get some parts :D oh an if they have the 2g mafs get it also an the connection because its better air flow an it will help you run better on fuel :)
I actually found some reducer couplers half the price but need to get one from 2.5 inches to 2.. And I think I already have a 2g maf haha thanks for the info though!
Thanks man but I think i'm just going to get some reducer couplers!
Here you guys go, the fmic kit. Now what pieces of this bumper do I have to cut out to install it? Does it all come off and go right in front of the radiator support or what? Sorry this is my 1st one!
Not sure if you got this installed or not, but your going to have to pull out the head lights and remove the bummer support. The front should look something like this.
oh man i almost threw up on myself when he said jdm fmic, sorry.
but have you even tried mocking it up and see what parts you need as in couplers, more pipping. looks like your going to have a long route fmic.
mock it up and go from there, but save yourself the trouble and hassle and just save up and get a used fmic thats intended to be on a 1g dsm. the money you'll spend on couplers, clamps, time and headache isn't worth it.
This project is like watching a kid trying to put a square peg in a round hole.
But really your going to have to cut peices of pipe and use couplers to make it fit right.
like i said buy a used one there are really good deals every now and then
