Archer Fabrications
- 9,719
- 707
- May 9, 2011
Scottsdale,
Arizona
Mods move to build thread if need be.
Well i bought a 6bolt long block complete a few weeks ago and i thought i would start a thread for the tear down. If i have any questions I'll ask them here in hopes bogus has insight, but i have a pdf manual also so everything should be good for me. My current motor, is still running strong and will be ran next season it was built by JPI racing in seattle washington. Jack stafford is a great engine builder.
I would use him again except i am all the way across the country in ontario canada. So with that said, This is a spare for my own learning experience of the 4g63 inside and out.
My over all plans for this spare motor. To hold 1000hp on a FP3794HTA
Magnus billet aluminum rods 23mm wrist pin
Ross pistons
And all L19 hardware where needed.
Magnus main girdle and ACL tri- metals.
Now since this is a spare i am I'm in no rush to have this completed. My only deadline is to have it finished by the time my JPI motor can't hold any longer (.035 tolerance) the origional goal was only 500hp max so I'm curious to see how she will hold 700hp and so is jack
In the mean time after disassembling i will be sending this spare off to magnus for cleaning, and I'll send it back for machining when I'm ready. The main immediate reason for the spare is to have a real world jig for making exhaust manifolds. Top mount t4 and bottom mount t3 or maybe forward facing.
Here are some pix!
She has 80k miles and only a blown head gasket so far, plugs 1&2 were soaked in oil. But no detonation to speak of on the plugs, we'll find out what the pistons say to that. I have no idea why the HG was blown in the first place.
this is my first time tearing down any motor.
Stock cams look a bit scratched on this intake journal.
Definately noticed some caked chunky oil in the pickup, in the head and in the pan. Most likely carbon chunks
And this is where I'm at now. Haven't taken off the head yet or checked bearings cause i have limited time with having my 2 week old daughter to take care of
I'll be back with bearing pictures and piston shots when inget there, so far I'm only a half hour into disassembily and things are going well,
Just got the 10mm 6point alan socket bit for the oem head studs can't wait! Love Tearing into my favorite motor
I also plan to do the oil port mod
and removing the blocks flashings.
Ross pistons
Here are some pix!
and removing the blocks flashings.Attachments
. Stand is right in the way of the rear main
off she comes again.
