Finally, after 3 years...
Mr Peepers
DSM Wiseman
1,272
28
Oct 16, 2005
Janesville, Wisconsin
Made it to the track. Cold track made it quite interesting, but here are the results:
[email protected] spinning through first/some of second and [email protected] with an easy launch/bog. Didn't expect anywhere near that :) If the track was warmer 11's definitely aren't out of the question as seen by the trap speeds :thumb: Best of 118.84
evo3, 264/272, 1000's, safc1 for tuning, dejon sidemount, and e85. Boost was about 21 psi with a little 22-23 psi spike after the shift, conservative tune(for e85 standards).
Video:
12.34 crappy spinning.
<object type="application/x-shockwave-flash" width="640" height="360" data="http://www.flickr.com/apps/video/stewart.swf?v=68975"> <param name="flashvars" value="intl_lang=en-us&amp;photo_secret=2c3110010f&amp;photo_id=3408935826&amp;show_info_box=true&amp;hd_default=false"></param> <param name="movie" value="http://www.flickr.com/apps/video/stewart.swf?v=68975"></param> <param name="bgcolor" value="#000000"></param> <param name="allowFullScreen" value="true"></param><embed type="application/x-shockwave-flash" src="http://www.flickr.com/apps/video/stewart.swf?v=68975" bgcolor="#000000" allowfullscreen="true" flashvars="intl_lang=en-us&amp;photo_secret=2c3110010f&amp;photo_id=3408935826&amp;flickr_show_info_box=true&amp;hd_default=false" height="360" width="640"></embed></object>
12.4 bogging then spinning
<object type="application/x-shockwave-flash" width="640" height="360" data="http://www.flickr.com/apps/video/stewart.swf?v=68975"> <param name="flashvars" value="intl_lang=en-us&amp;photo_secret=7794d4776c&amp;photo_id=3408224835&amp;show_info_box=true&amp;hd_default=false"></param> <param name="movie" value="http://www.flickr.com/apps/video/stewart.swf?v=68975"></param> <param name="bgcolor" value="#000000"></param> <param name="allowFullScreen" value="true"></param><embed type="application/x-shockwave-flash" src="http://www.flickr.com/apps/video/stewart.swf?v=68975" bgcolor="#000000" allowfullscreen="true" flashvars="intl_lang=en-us&amp;photo_secret=7794d4776c&amp;photo_id=3408224835&amp;flickr_show_info_box=true&amp;hd_default=false" height="360" width="640"></embed></object>
Nice runs!!!! Not downing your car, but nice with what mods you have!
Nice... Good job!!
I'm going to the track on May 1st. I hope to finally put this car into the 12's.
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/pFXQ7kYKOP4&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/pFXQ7kYKOP4&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Im sick of 12s!! Been running 12s for three years! I want 11s:hellyeah:
If i could just get your trap speeds i would be good!!
Turn the boost up.... :hellyeah:
I was running 20psi for the past 3 years, this year i did turn it up (26psi) havent made it to the track yet April 11th is opening day!
I'm curious to see what the SBR G60 does on Dave's car with the .63 a/r T3 turbine housing. Dave has successfully murdered every Garrett Hybrid turbo that was bolted to his car, including a SBR G50, eBay GT35R, and Turbonetics 60-1....for some reason the G60 (backup turbo) is still alive. The only turbo that has allowed him to net a full season of use was a TD05H 20G. That should say something for Mitsu reliability!
Nice job, Matt! I had to read deeper....I thought at first you were netting those times on that modded 14B that was giving you so much boost creep trouble in early January.
Was that at Great Lakes? Can't wait to go there sometime this month.
Yes sir it was! Watch the video again and check the barrier between the lanes...it says it right there :) I'll be there in July once my car is finally done! I can't wait :thumb:
Definitely a good time Matt. It will be nice to see what you can run with more traction.
Good job, Matt! Can't wait for you to hit 11's this year.
As long as it's after I hit 11's first.
Went again tonight... could only muster a 12.1
Even spun in 2nd a little, definitely need to wait till the track warms up.
That's still a nice run, Matt. I hope to dip into the 11's by this summer, so we'll see what happens. Maybe I'll see you there! Again, nice run.
<object type="application/x-shockwave-flash" width="640" height="360" data="http://www.flickr.com/apps/video/stewart.swf?v=71377" classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"> <param name="flashvars" value="intl_lang=en-us&photo_secret=f4cbe38202&photo_id=3485336496&flickr_show_info_box=true&hd_default=false"></param> <param name="movie" value="http://www.flickr.com/apps/video/stewart.swf?v=71377"></param> <param name="bgcolor" value="#000000"></param> <param name="allowFullScreen" value="true"></param><embed type="application/x-shockwave-flash" src="http://www.flickr.com/apps/video/stewart.swf?v=71377" bgcolor="#000000" allowfullscreen="true" flashvars="intl_lang=en-us&photo_secret=f4cbe38202&photo_id=3485336496&flickr_show_info_box=true&hd_default=false" height="360" width="640"></embed></object>
Well the clutch didn't like it, but I sneaked out an [email protected] Boost was about 24-25 falling to 22 by redline, high 11 AFR and base timing set at 2*BTDC. Otherwise no other changes.
Sorry Eric :p I couldn't wait.
congrats hopefully i get my 20g back this week and go to the track and run some good times like you but easier said than done LOL:pray:
Congrats, Matt. Looks like that Cardboard Fiber Interfooler really did help out.
I'll get there. ;)
