mini zilo
- 783
- 19
- Jul 17, 2006
Chicago,
Illinois
I feel like many people have their cars setup in ways that could be GREATLY improved over how they currently are. I am talking about small things though. In my case, I am talking about a 16g setup. I want to extract the MOST possible power I can out of it before I get rid of it. Does anyone take things like fluid dynamics and thermal insulation into account when they setup their car?
Your engine bay is full of heat, and you are trying to keep it cool. So wrapping things with a thermal insulator would help to keep hot things isolated from things that need to be cool. So what kinds of things would need to be insulated? Intercooler piping? Radiator hoses? etc...
What about the way your intercooler piping is designed? Is there possibly more power to be made through an efficiently designed intake setup? Do things like the angle of pipe bends, and stuff like that really make a difference in how much air is able to flow?
Are you able to free up restrictions just by properly designing a better "track" for the flowing air to take to your intake manifold? Do little things like this actually make a difference?
Does anyone else have anymore suggestions for things that could be improved upon in most peoples cars besides intercooler piping design and insulating the hot stuff and keeping a barrier around the cold stuff?
) All of these little things not only add up to a tad bit of extra power, they go a LONG WAYS towards having a better overall performing vehicle with some added reliability to boot. So is it worth doing? YES... Is your main result going to be shear power? Most likely NOT... Will there be a noticable gain in the cars OVERALL PERFORMANCE and ability to function more consistantly? YES !!!
This can actually cause them to lose power. Their using such a large pipe can reduce the velocity of the exiting exhaust and hurt power. All of your parts you put on a car must be designed to work together in harmony. BIGGER ISN'T ALWAYS BETTER!!!!
OEM oil requirements are meant for the heat the engine of originally designed to produce. Oil will thin the more it is heated. This increased heat from more power will thin the oil to the point to where it is now longer effective at cushioning the forces against the bearings. This is why in modified engines should use a slightly higher weight oil to help maintain oil viscosity at these higher temperatures.
