External Wastegate
You will need to determine where you want the wastegate to be mounted. There are 3 different options.
-o2 housing
-exhaust manifold runner #1
-exhaust manifold collector
You can do a search to find out what the pros and cons are of the different mounting options.
Then you need to determine if you want to dump it to the atmosphere or if you want to recirculate. This should be based off of sound (louder if you dump) as well as emissions testing if your state has it. It will not pass if it's dumped.
Then it's pretty much a bolt on process.
