WOTDSM
- 167
- 0
- Dec 3, 2006
Detroit,
Michigan
Cool man. Just keep in mind you'll have to redo the SD VE Adjust tool for cruise conditions since we've just made cruise 4% richer.
But it's not very hard to run a trace with link and do it yourself if you can do some math and estimation in your head quickly.(IE Keeping it simple... Say you just hit a cell of 100 and you are 5% lean still, Just change it to 105 et cetra) I'd do that an Work out to interpolate things a bit farther as well as smooth out an extend to an extent some of the High spots on the edge of what you have been hitting in the map. So you don't end up 12% lean in a higher load cells as being that lean at 20+psi is going to piss the car of a lot more then at around 15psi.
What are you using to control boost and why are you running narrowband simulation when your logging your WB through your EGR input?So I have some questions.
The first log I have here is just me driving through traffic. If you look closely at any point where I totally lift off the throttle or just step back on it a little, my AFRs are out to lunch. What do I have to change to get them proper? Why does the AFRest not go to full lean when I let off and no fuel is even entering the engine?
Second log is another third gear pull, my AFRs are getting pretty close, but any more help and advice would be appreciated.
Bottom line, my idle is good, my WOT is getting there, but I'm still not satisfied with everything in-between, mainly my throttle response.
Even with coasting fuel cut (off the throttle and decel) and a WB readings of 22:1 your AFREst will show around stoich because it pulls the AFREst data from your OLMax/MinOct DA table.
At first your BoostEst and Omni readings threw me off a bit, they were consistently 5psi off throughout the pull when usually they track close to about 5.5k if your WB matches your AFREst. For whatever reason your engine displacement setting in BoostEst was 2.7l so moving it to 2.0l made them track close. That being said, I'm impressed by the airflow numbers you're getting out of the 14b on such low boost, kind of leaves me scratching my head to be honest.
With the mods you've got and the airflow numbers you're logging I'd be extremely happy with that tune. It looks like you could lean out the 6.5k/7k - 29.4/31.2 VE cells a few % to clean up that AFR at the end of the pull. I'd also play with timing advance during spool-up as well as leaner spool-up AFR's and see if you can't get it to spool faster. You could also bring timing back faster after peak torque, knock permitting of course.
Boost control is just a mbc, and my LC-1 setup and inputs was all set-up two years ago. That's what I had understood to do at the time and have assumed that was correct.
Ah, okay, simple enough.
I've been told to not worry about BoostEst but rather just the AFRest/Wideband, or no?
Airflow wise, I have no clue how to know if my numbers are accurate or not. I just assume as I play with the VE table that it would change accordingly.
Okay so leaner and more timing will help spool, I'll try that.
Thanks, I'm just trying to always keep learning.
Less timing helps spool up. the closer the spark happens to TDC, the faster the turbo will spool.
BUT, Just because your are spooling the turbo up sooner... . Doesn't mean you are making more power
