- Thread starter
- #126
JusMX141
Moderator
- 15,147
- 1,289
- Dec 13, 2005
Greensburg,
Pennsylvania
Yea, if he's flowing 40lb/min at 20psi then he is right at 80* efficiency at peakwhich we're all sure he's not. He's likely running 35-38lb/min and thus in the 74% range at 2.3PR.
Is there any surge? 4500 rpms is well within the spool range of a gt35r. Nice! I forget, did you measure the wheels?
Compressor- 62mm inducer, 82mm exducer; 6-blade.
Turbine- 68mm inducer, 62mm exducer; 10-blade.
T3 turbine inlet, Garrett 4-bolt outlet.
4" compressor cover inlet, 2.5" compressor outlet.
I think the boost will touch 25psi before long. Once he gets over this turbo feeling faster at 20psi than the 20G it replaced did at 25psi, then the boost will inch it's way up.
I'll have to ask him about surge and get back to you. I'll also report back with actual spool RPM once the tuning gets cleaned up a little (I think it's currently around 10.8 on the wideband @ WOT running 93 fuel.)
