d2 coilovers settings
QCV8eater
104
Sep 9, 2004
quebec,
Hey!
I own a d2 coilover kit for my 2g and was wondering what settings do you guys run? I am currently at fully turned in, then :
Front : turn out 720° (2 turns)
rear : turn out 900° (2½ turns)
I think the ride's a bit bumby but I can't seem to find a good setup...
So... what are your D2s set at?
Thanks,
Phil
What spring rates did you go with? As for mine, they were stiff untill o got to all the way turned out (lowest setting).
I would have to say just leave it 2 turns up from full-turn out. Any more than that, its probably going to be bumpy and there wont be much adjustment due to the 50/50 damper.
Those are the same rates that I went with... and my is a bit bumpy too, at most of the settings. There really isnt a "best" setting, its just what setting you can put up with and how bumpy the roads are around there.
