99gst_racer
Moderator
- 12,010
- 1,707
- Apr 5, 2003
Coloma,
Michigan
The screenshot I posted above is Wilwood's 94-04 Cobra rotor. 12.9" rotor, with the same offset. The draw to the 2-pc rotor is possibly being able to manipulate the hat to make the rotor fitment more ideal. But you are correct that they aren't cheap at all. $1050 for Wilwood rotors VS ~$150 for a 1-pc drilled/slotted set.We didn't tackle this project with a Wilwwod rotor in mind for basically 2 reasons:
1. They are expensive
2. We would have to start from the beginning, finding a rotor of the correct diameter, thickness, and determine the offset.
The Wilwoods we stock for 2g are too small at only 12.2". These calipers require a rotor around 13" diameter. Also, we already stock the Cobra rotors as we use them in a lot of our other brake upgrade kits and we already have the hubcentric rings for them.
I'd be willing to give the 2-pc a try but Wilwood is out of stock on hats right now. I'm capable or shortening their hat, but I'm not set up to produce my own hats from scratch.
