2G Rear CTS-V brakes
jakelandry
985
169
Oct 13, 2009
Minden, Louisiana
I know there's a lot of information on the site about CTS-V front brakes but I cant seem to find anything about the rears.
Does anyone know if they'll bolt straight up, what the ear spacing is, what size rotors will fit, etc? You can pick the front calipers up on amazon for about 120 a piece and the rears for about 100 a piece. If you're like me and have 95 vented rear rotors and calipers and are in desperate need of replacements, you know how big of a pita it is to find all the parts at a decent price. I just don't see any sense in investing the same amount of money in our stock 2g rears if we can have Brembos for nearly the same price. I know the 4 pot CTS-V rear setup should throw the braking bias straight down the drain, but I thought maybe if you put them on a smaller rotor or something to that nature it could work.
Any input is appreciated.
Fwiw after days of searching I found this bracket for the rears to go on some car. According to this the rear mount spacing for the ctsv brembos is 119mm which could be interpreted as the 130mm our cars use if you factor in the extra 1/2 inch from the bolt holes so I suppose it is still up in the air whether or not the bolt spacing will allow them to bolt up but we're closer.
