kyler021
- 242
- 178
- Aug 29, 2023
Pasadena,
Maryland
Hey guys,
I bought everything listed on the CTS-V brake swap website for this upgrade, only to find out that the adapter does not fit onto my hub (I’m not sure if the hub was swapped or not prior to my purchase of the car). The adapter hits the middle part of hub, as shown in the picture, causing the adapter to bounce around as shown in this
video.
Anyone with more experience than me want to chime in as to what my options are?
I’ve seen a couple options in this thread, like shaving 3mm off the caliper mounting ears, and adding a 3mm spacer in between the rotor and hub, instead of the 5mm adapter provided in the brake swap kit. Then I’ve seen someone just shave 5mm off the caliper ears, use no spacer and it bolted right up.
I’m not quite sure if either of these would work, as people really haven’t had issues with the hub itself, it’s mainly just clearance issues with the rotor and caliper that I’ve seen in the threads I’ve read.
Any help is greatly appreciated!
Kyle
video.
Kyle
