building a custom bellhousing for the 6G7x series
Bill Hincher
49
3
Sep 12, 2006
Toledo, Ohio
how are you going to start? well I need a datum line and what better place to start then to cut an engine in half and begin the build, the first step to a long journey starts with the first step, DO IT NOW!
this swap required a flex plate as well as a bellhousing
an adapter had to be built as well
the ring gear is installed and the converter is fit
I needed to shape the bellhousing from some scarps of aluminum
I love welding >;o)
the starter needed to be located and mounted, in this case I used a reverse starter location to aviod the steering linkage and get ground clearance
then everything gets molded in
after a LOT of snading and sanding and SANDING, the molding is done
I keep using the datum lines to keep it straight, its a long process
then it gets casted, the pattern is on the left and the cast housing is on the right
the numbers for the machine work was gathered before the tear down of the build, so I can cut the blot holes using the CNC bridgeport
then it all comes together
you can find the U tube vidoe on the starter testing here
http://www.youtube.com/watch?v=H1V3cIFwf14&feature=youtu.be
Wow!
You are one awesome dawg if I must say so myself.
The proof is in the pudding my friend.
Nice work! Please share more. I LOVE stuff like this.
Those 6g motors sure are hefty bastards! Great work, I need some of your skills for my 3g 4g64 bell housing adapter!
Hi Bill
Glad to see your magic, I am very familiar with all your work from Project Zero, read all your posts in it, and made a couple suggestion to you before,
For the members in this forum that may not be familiar with your work all I can say is, THIS MANS WORK IS AWESOME.
This is the first time I see a post from you on this forum, I most certainly read the others like right now,
Anyways a belated welcome to you and your work.
arrowhead
Found the website. You've been very busy. Think I have some idea's brewing for my blazer.
I"ve always been thankfull that you are out there building your Bell HOusings for the 4G63 and the other engines/trannies you work with. And although i haven't gotten to it yet i've always planned on a 4g63 powered, small RWD roadster as my ultimatelittle "kit car"
It's guys like you that have the means as well as the drive to make these parts that really help fuel and keep the mitsubishi racing game alive and well... thanks again for all you do Bill, we need more people like you!
