Broke A Piston Wrist Pin.
Okay the alternator will be relocated to the rear of the engine next week. I purchased the jay racing relocation kit in steel not aluminum. The kiggly HLA and crank trigger also will be installed. She is getting closer to completion:D
Ive never had good luck with imageshack. They always load slow for me. I would recommend imgur: the simple image sharer
They're fast and they strip gps location from the pictures. Also no need to register.
Here is the trick I load all my pictures right from my phone through tapatalk always do it to this forum and not tapatalk hosted. HTC Thunderbolt.
That does work easy. Quality is good. Looks like it does "do not resize" by default (full resolution).
Image Shack "do not resize" makes JPG file twice as many KB from the same photo input, so, presumably less compression in the jpg compressor they use. Both seem like really good quality though.
Kel, if it's fine by you, do you mind if I print the pic of your engine and make sweet love to it? I promise to not leave a single part un touched :)
On a side note. . .
Great job, and keep up the good work!! Nasty build indeed :)
On a side note. . .
Thanks
Sweet Kels! Keep up the good work!:thumb: The cyclone mani looks crazee as well. Nice job!
Question I've been look for 95+96 specific cam gears and I can't find any? I need to degree my cams to bring my compression back up but I've modified my timing plate so I need to use it. Problem is no gears I see have to provision for 4 screws for the timing plate? Maybe you have found such?
Btw loving the build man. Engine is beautiful!:thumbup:
Fidanza gears have the holes to attach the 95 trigger plate. But you need to retrofit to a 1g sensor so you can reset the timing after you adjust the cam gears.
Will need to adjust timing? Im only adjusting a degree or two to get to factory timing i think anyways. Evo 8 cams aftermarket
Okay I purchased a s90 throttle body so now its time to modify the cyclone to work with it. A video will be posted later today. I tested the most shallow area on the cyclone to see if there was clearance for the 70mm unit without cutting all the way through the manifold and for all that need to know it will work:thumbup:
It fits the cyclone:thumbup:
Kel the top photo right next to the throttle body,do you think Misu still carries that bracket ,I'm missing both of them! Also nice job with everything you are doing there. impressive!:thumb:
I highly doubt it I will see if I have some. If not I will make two aluminum brackets after I get your manifold back from being powder coat shop. I still need to know what color you want to go with.
