2G Wrist pin to rod play
okm12346
565
22
Dec 3, 2007
Chicago, Illinois
So I have these brand new manley wrist pins and new eagle rods. The pin goes in the piston and its pretty tight, but when I grab the piston and move the rod, i can feel a very tiny bit of play. Is that normal? is it because of the floating type piston. I cant remember how this was with the pistons on my other car.
Thanks
it sounds right to me. the rod should be able to slide easily on the wrist pin. the slight amout of play is because it has to have a small amount of clearance to allow for movement and to oil the bearing
small end bearing
Have you checked the clearances? .0008"-.0015" depending on the application is a normal clearance. Most of the time the Piston to pin clearance is to tight.
Just as rings must be fit to the bores, rod small ends and piston bosses need to be fit to the pins.
People think you can bolt parts together and go. It doesn't work like that. Every clearance must be measured, and corrected if it's not in spec.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
