boost controller problem
white98gst
122
Sep 16, 2004
ontario, California
aight i just installed a hillman boost controller. but when i tune it, no matter what my boost guage always says 10 PSI but it creeps to 11 then goes down to 10. sometimes it feels like alot more than 10 psi. is it my guage or the boost controller
where are you running the line from???? turbo outlet or the BOV line???? i did mine off the turbo directly and have had no issues....if its not that...something may be pinched such as a vac line for the guage or controller....
Bypass the mbc and go for a drive. Boost leak test if problem persists. If not, check your mbc set up.
Maybe your BoostController is backwards?
Sure you can.
