Big 16g rebuilt 0 miles
Sjd6795
614
121
May 14, 2014
Wilsonville, Oregon
Found a turbo on facebook a guy is selling from a dsm part out. It's a 16g that's been freshly rebuilt. Everything is good besides its missing the exhaust housing which my 14b works so all good there. It does come with the j pipe and I offered $170 am I getting a good deal?
If its been rebuilt, try to find out who did the work and ask why it was rebuilt. See if you can check or have pictures sent of any alignment markings to make sure it was put back together properly, especially if it wasnt rebalanced on a rig afterward.
Personally I would be taking it apart anyway to make sure whomever rebuilt it at least did a passable job and kept the insides clean. Small clearances, 150k+ rpm, and crud dont mix.
Thanks guys, sent him a message rethinking the offer. Also asked more about the rebuild. I think hes just done in general with DSM he has a built 7 bolt block among other things as well as a FP Green that's been rebuilt he is selling everything.
There was also this one.. rebuilt by Texas rebuilds and also comes with another rebuild kit
Fb link isnt working. But it's a 16g 20g hybrid MHI tiny nick on compressor blades asking 250
Hard pass on that second turbo, compressor housing wasn't machined correctly or is the wrong one for the comp. as you can see from the massive gap between the blades and housing. Also, that blade being messed up isn't confidence inspiring.
This looks like someone whose got some spent junk leftover and is trying to make a few bux before fully bailing TBH.
So far I haven't seen anything other than cores to use and would really only pay as such..
How much does he want for the green?
I'm not seeing anything here that signifies it's been professionally-rebuilt whatsoever. Might've been disassembled, had a cheap-o parts kit slapped in, then reassembled with no balancing...but there's definitely no cleanup done to any of the essential parts on this unit and missing the turbine housing and actuator I'd place the value under $100.
Nope.
No actuator, turbine wheel is soaked, wastegate flapper is distorted and needs replaced, whole unit needs rebuilt, and it's a very old unit using what appears to be a Garrett E46 compressor so you'll never find a direct-fit compressor wheel if something were to happen.
  • For sale 2g 2g GST auto trans case
    2g auto trans case. With bearing plate and end case covers. Good condition. Trans was like...
  • Wanted 2g 2g radiator support
    Im looking for a radiator support if anyone has one
    • Fundsm
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$Kigglys 12 tooth billet crankshaft triggel setup 250$...
    • GST2012GSX
