Big 16G Turbo exhaust Housing
SlowChild3
545
9
Aug 19, 2005
Dayton, Ohio
<img src="http://www.dsmtuners.com/gallery/files/5/5/3/5/0/post.jpg" alt="Turbo Housing" />
<img src="http://www.dsmtuners.com/gallery/files/5/5/3/5/0/summer10_004.jpg" alt="Summer10 004" />
<img src="http://www.dsmtuners.com/gallery/files/5/5/3/5/0/summer10_003.jpg" alt="Summer10 003" />
Whats going on here? I assume the flapper arm has been cut and rewelded? It doesn't match up with the hole at all. I'm thinking about junking the turbo as it needs rebuilt. Found kits for $30. Housing for $250. Seems a little steep. Might as well buy new. Thought about porting and not worrying to much about the cracks and maybe installing a larger flapper. As for the flapper arm whats going on? Thanks for advice/opinions.
Search on EBay for the housings. Wes (knoochgoon24) bought an eBay housing and hasn't had any problems with it. It was around $80 IIRC.
+1 for that
I just put a new ebay 7cm housing on my 14b and it works very well. The only thing is that I think the wastegate elbow is different. You will need to find a custom way to attach the actuator. The arm on the housing is too large for the small hole on the actuator arm
Justin (jusmx141) has told me that the ebay ones are prone to crack less and has see mitsu housing crack all the time.
goodluck
Actually, I did have a problem. They are on 5 week back order through several of the companies. I'm still waiting on my refund... :rolleyes:
Other people have run the eBay ones though.
