snowborder714
Moderator
- 16,188
- 465
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
Well, that shoots that idea out the window (other than the fact you have a well designed aero kit)
I have mine in my oil filter housing mainly for convenience of install, but I also wanted it post-engine pre-cooler to see what the max oil temps were. Oil pan is going to be post-cooler, isn't it?
Wish they had one of those back in the nineties. Wouldn't have to drill and tap. But yeah, that location works very well.Easiest way to add an oil temp sensor is to drill and tap a stock oil pan bolt or buy one of these.
STM Oil Pan Drain Plug with 1/8
The STM M14x1.5 engine oil pan drain plug is machined with an 1/8" NPT temperature sensor provision to allow you to install a temp sensor right into your drain plug. The plug itself has a M14x1.5 thread which fits most Mitsubishi including DSM, Evo and 3S and some Honda, Acura and Mazda models.stmtuned.com
You are all welcome.
You can see a lot of mods in my car's profile https://www.dsmtuners.com/dsm-profiles/john-freunds-time-attack-99-eclipse-gsx.1768/What oil filter housing you runnin? 1990 air cooled? Where did you plumb the sensor and what type????
