munchlax
- 1
- Aug 26, 2010
Redding,
California
Ok so i was told the CEL was because of the map sensor and O2 sensor, I got a used map sensor, CEL still on. maybe O2 sensor?
Throughout all the gears, pedal to the metal, SLOW acceleration! boost goes all the way up, rpm jumps up and down, barely go up a hill, can barely go past 45mph. maybe boost set too high? fuel leak? fuel filter? no back pressure? (the air comming out of the exhaust is puttering..... miss fire?) (I changed the spark plugs to bosch platinums today, no oil on them, wires are in right place... i think)
Is seafoam eclipse gst safe? Anyways I seafoamed it today..... did it correctly, came back home after the high rpm(I tried to keep it high) drive and once i came back home..... smoke everywhere. looked under the car, it looked like it was comming off of the exhaust piping, down pipe, turbo manifold. maybe too much pressure in exhaust, too hot? something inside exhaust?
Need help asap! I'm begging YOU!
