19BLACKGST98
- 711
- 3
- Nov 6, 2003
McKinney,
Texas
He did it on a 4g63 DSM. I think he has 3 DSM...one in the 9's one in the 10's or low 11's and one in the 11's. He must just not get the Meth injection concept. So when I get my car tuned on race gas should I run pure meth? When I get it tuned on pump is it more beneficial to run 50/50 do to the cooling of the water? (sorry I read this whole section a couple of times a few months back when I was deciding on getting meth injection but I am in class right now on my Cell so I cant catch back up right now)
! Tuning nightmare with that much fuel just cutting on at random airflows!!! You would be better off mixing in the gas tank 2 parts meth with one part gas and upping your injector size by 1/3. Then your stoich of the mix would be about the same as e-85 and your octane would be about the same. So switching to e85 would make more sense than pure meth injection for the most part if you're looking for over 103 octane. The amount of meth required to raise the octane gets higher and higher for a very little increase in total octane as you get over 100. The pure meth injection at 3-4 times the requirement for pure water will give you 99-100 octane and will give you the very effective cooling property of methanol. It takes out more heat per part than ethanol and has a MUCH smaller droplet size-- larger surface area in the mist-- than water or even ethanol. It is plenty. And octane is overrated. A cool aircharge with 100 octane is better than a hot aircharge and 105 octane any day of the week.
