420A Anyone got an oil pump or water pump
That’s valid
How many miles are on the engine you are rebuilding? Most cases I would go with a new water pump but run the old oil pump. I would probably take the cover off and check the gerotor and plates for excessive wear as long as the engine was apart.
I know my motor has at least 215000 miles and it spun 2 bearings as well so I would feel safer just having a new oil pump, problem is most modern ones are made of junk and fall apart so I want something oem
You can still buy the OEM water pump. Part#: 68382490AA
But with their prices varying from $65-$120 I would just buy a $15 one from RockAuto. I've never had a problem from those.
