2G 97 4G63 INTO A 95 ECLIPSE,
davidpredmore
Jun 9, 2026
cocoa, Florida
I swapped a 97 4g63 into a 95 Eclipse GST. I know the cams are different so I did remove the rear one off the head and installed the plastic plug, then I removed the intake cam gear and installed the cam sensor from the old 95 4g63 but when I went to put the cam gear on from the old 95 4g63 onto the 97 i notice the timing mark is completely on the other side of the gear. When I removed the old one I didn't move the cam at all.
Do I have to turn this cam all the way around to get to the timing mark on the 95 gear or leave it cause it was in time before I took the 97 gear off? I did notice when i put them together that the timing marks were off by 360 from each gear.
So I put the 97 in time before I removed the gear then I installed the 95 cam sensor and when I went to install the 95 intake gear on the cam it would only fit if I turned the gear 180 to fit the pin. So now that mark is facing the other way. I took it off and matched it with the 97 and there the same except the marks are 180 out from each other.
I put the 95 on the 97 to show how it looks but the engine is in time with the gear i took off of it
You can see the pin one one is up when in time and the pin on the other is down, the pin that holds the gear.
You have it wrong. The pin on the gear goes up. Both of them are wrong. Do not turn them if your crank is at TDC. Move the crank away from TDC a little bit so none of the 4 pistons could contact valves while you're turning the cams.
Here is what is confusing me. I bought the engine in the 97 GST and drove it around the guys shop and into my car trailer then out and into my garage and this is how it was timed when I took the engine out of the car and it ran good too.
I'm not understanding what you're saying. The crank can line up dowels up and dowels down on cams because cams turn half speed of crank.
For proper setting of all 5 marks you typically run dowels up on cams and set the other marks on point. Only other gotcha is the rear balance shaft phasing.
How the motor sat when removed isn't relevant. If it was properly timed you should've been able to turn the crank and within 6 revolutions all marks would line up with crank on #1 TDC and cams on mark with dowels up. That's is a certainty every 6 revolutions.
Found out the timing gear had two marks on it.
You're still setup wrong. The cams need to be dowels up. Your first pic where you're trying to figure it out is dowels down. The 2nd pic where you state this is how it was, is dowels up.
